6.40.3 Dude DB corrupt, how to fix it??
I don’t care about the data, just want the objects and structure back.
When I try and log on it works for about 30 seconds, then logs out and DB error.
What is the process for restoring the functionality in this version??
Thanks!
Sterling
I had the same error recently. I opened the ticket at mikrotik support, but they were not able to solve the problem. Finally I imported older backup and everything works fine like before. I try it as well.
I do have a backup from May.
I think it was from 6.39.1.
Are you saying there is a way to use that image/db and restore it somehow into the 6.40.3 running version?
Or are you saying you simply reverted your entire image of the system back to a previous version?
I can go back to May’s version I think, but then I have to create all the structure/objects I had added since then.
You can import whatever version. Just try it.
