6.41rc34 - wireless fixed rate selection
Hi Mikrotik,
Can you explain the bug that was fixed by this on the 6.41rc34 changelog:
*) wireless - fixed rate selection process when “rate-set=configured” and NV2 protocol is used;
Thanks,
Richard
Routers could reboot or get stuck (freeze) at some point with such configuration.
Ok. Thanks.
If someone had this problem and are trying this update, then we would really appreciate any feedback on this.
Good day
I have had this problem on my netmetal 5 for about 2years only on ptmp not ptp. Where the sector will have a watchdog restart every 2-3 weeks for no reason at all. I have replaced the cable,poe and also did a netinstall and nothing have solved this problem. Created a support ticket but nothing helped. Have not done the update on this sector because of new bridge configuration. Will gladly update when this version comes out of RC and post feedback.
Reason of Watchdog reboots can be also something else. However, if you have configured rate set and use nv2, then there is a high possibility that fix will solve your problem.
Good day
I upgraded to rc version and tested it and it still does the same. I have send supout.rif to the reply of old ticket Ticket#2017040622000427.
Let me know if need more info.
Thanks for progress on this problem.
