6.41rc52 No supported channels
Hi there,
I’m seeing a new issue with 6.41rc52 where the router reports “No supported channels” on wifi. This may be related to some of the channel changes that I’ve seen in the changelog “wireless - updated “united kingdom” regulatory domain information;”
This gateway was part of a mesh and was fully functional. I then shutdown the other members of the mesh leaving just this gateway online when it started showing the message. It does not appear to recover.
I use a custom scan list and the united kingdom region. The scan list contains 4 channels at 20MHz width each. 5180, 5200, 5220 and 5240.
It doesn’t look like anybody has posted about this issue before.
[admin@NG200B021700119] /interface wireless> print
0 ;;; no supported channels
name=“wlan1” mtu=1500 l2mtu=1600 mac-address=64:D1:54:xx:yy:zz
arp=enabled interface-type=Atheros AR9888 mode=ap-bridge
ssid=“my ssid” frequency=auto band=5ghz-a/n/ac channel-width=20mhz
secondary-channel=“” scan-list=20Europe wireless-protocol=802.11
vlan-mode=no-tag vlan-id=1 wds-mode=dynamic-mesh
wds-default-bridge=MyMesh wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=MySecurity
compression=yes
Disabling and re-enabling the interface does not fix the problem.
The strange thing is that if I run a background scan that it “finds” a channel and allows the clients to connect while I run the background scan. It keeps working for as long as the background scan is running.
If I stop the background scan it goes back into the “no supported channels” error condition.
I don’t know how to detect the failure condition with a script and correct for it.
If I change the scanlist away from my 4 channel scanlist to default, it finds a channel and works again.
Edit: If I replace my 20Europe scanlist with the four discrete channels that my scanlist anyway contains it also works.Under interface scanlist I have 5180, 5200, 5220 and 5240 instead of 20Europe which is listed under Wireless channels as those same four channels.
Is that indoor or outdoor usage?
In the most EU Country’s 5,2Ghz Spectrum (Band 1) is only allowed for indoor usage
It’s all indoor use yes.
