6.42rc37 CCR Disk full - can't upgrade
Hey!
I am having a weird issue with my CCR - I was trying to upgrade but I found that I have like 9MB free although I have no files in /files, I am not using dude or user manager (which are known to generate lots of log as far as I found here)… I am also not using any additional packages I could uninstall. Is there something obvious I missed? Where is the free space taken? Where can I monitor any space usage taken by files which are not listed in ‘/files’ and how can I free up the space (which is not taken by anything important otherwise I’d know…)?
[admin@MikroTik] /file> print
 # NAME                                          TYPE                                               SIZE CREATION-TIME
 0 autosupout.rif                                .rif file                                      657.2KiB jul/20/2017 20:11:09
 1 BACKUP_PPTP_OVPNSRV.backup                    backup                                          61.9KiB jul/20/2017 20:11:09
 2 autosupout.old.rif                            .rif file                                      631.3KiB jul/20/2017 20:11:10
 3 skins                                         directory                                               jul/20/2017 20:11:10
 4 config.backup                                 backup                                          45.0KiB jul/20/2017 20:11:10
 5 Wdc.key                                       .key file                                           657 jul/20/2017 20:11:10
 6 backup_02062015_1505.backup                   backup                                          26.5KiB jul/20/2017 20:11:10
 7 backup_20062016.backup                        backup                                          84.1KiB jul/20/2017 20:11:10
 8 pub                                           directory                                               jul/20/2017 20:11:10
 9 ca_tiger.crt                                  .crt file                                          1818 oct/15/2017 13:41:51
10 ca.crt                                        .crt file                                          1192 mar/07/2018 10:23:25
11 kipp_server.crt                               .crt file                                          4608 oct/18/2017 14:58:46
12 kipp_server.key                               .key file                                          1679 oct/18/2017 14:58:52
13 MikroTik-20180212-2130.backup                 backup                                         162.3KiB feb/12/2018 22:30:03
14 server.crt                                    .crt file                                          4638 mar/07/2018 10:24:05
15 server.key                                    .key file                                          1704 mar/07/2018 10:24:23
16 MikroTik-20180514-0854.backup                 backup                                         169.6KiB may/14/2018 08:54:27
[admin@MikroTik] /system resource> print
             uptime: 35m16s
            version: 6.42rc37 (testing)
         build-time: Mar/01/2018 09:29:31
   factory-software: 6.34rc21
        free-memory: 1747.9MiB
       total-memory: 1956.2MiB
                cpu: tilegx
          cpu-count: 9
      cpu-frequency: 1000MHz
           cpu-load: 0%
     free-hdd-space: 8.6MiB
    total-hdd-space: 64.0MiB
  architecture-name: tile
         board-name: CCR1009-8G-1S-1S+
           platform: MikroTik
Thanks for any help!
Hey,
To what version of ROS are you trying to upgrade?
Tried 6.43.rc12 and 6.42.1 but both require 15MB free…
You could try upgrading through a Netinstall, as i think your total HDD size is somewhat less than it should be, that should fix the issue.
