6.45.7 CPU issues?
We’ve upgraded our CCR 1036s to 45.7 but ever since upgrading, we started noticing high CPU utilization whenever WAN interfaces reach maximum bandwidth capacity
Our topology is the Core router and then connected to 2 Edge routers. When Edge 1 was having issues with CPU due to high traffic, we routed traffic to the other Edge and that too suffered from high CPU utils
Traffic is route marked but no logging applied on the mangle rules
Any help would be appreciated
Thank you
What version was installed before 6.45.7 that didn’t have high CPU problem?
We have the same problem on simple queues on 6.45.6 on our 1036. It caps our bandwidth to 400mbps with CPU reaching 100%. We tried to change queue type, queue size, but only success was when I disable the queues completely.
We were at 44.2 if I remember correctly. I have both simple and queue trees enabled. Will give this a go and see if it improves
Also when checking CPU profile, cpu5 goes up to 95% utilization and “management” is attributed to that utilization
My guess is that management process actually deals with winbox. You should try to connect to the router using terminal only (no winbox) via ssh (e.g. use putty for windows) … and observe CPU load from CLI.
Commands /system resource print (for overview) or /tool profile cpu=all (for details) should show you real router state.
