Hi Guys,
I updated wap60 and nRay60 Ghz devices to 6.47.10, and got freq 66960 Mhz, but when i select it I get the following error
failure: frequency 66960 not supported on this interface.
Do you have any info, is this freq can be used?
Thanks s lot,
Best regards
Nikola
This works on 6.48.2 version
Mikrotik support wrote
this will be available on new 802.11ay hardware.
Unfortunately this cannot be used reliably on our existing 802.11ad devices - that is why this frequency support is removed
Sad, because Ubiquiti supports 71GHz on their 802.11ad hardware, which is way higher.
Just because Ubiquiti supports it on their hardware doesnt mean it is good nor reliable… I think MikroTik doing a smart thing, also this will push new hardware sales to MikroTik. Refresh cycle. As I’m sure all new equipment will have ARM processors and support rOS 7…
