My experience using RouterOS 6.49.19 on a CCR: after the update, the internet traffic started acting strangely — it occasionally drops to 0 kbps – 1 Mbps for about 2–3 minutes before returning to normal. Has anyone else experienced the same issue? I’d really appreciate any solutions from those who’ve managed to fix it.
"the update"?
Version 6.49.18 was introduced July the 7th, is that the update you are referring to?
What version where you running?
Care to share your config?
/export file=anynameyoulike
Remove serial and any other private info, post as Preformatted text by using the </> button.
What happens if you downgrade to the version you upgraded from?
