I want communicate two mikrotik by the OpenVPN and configure OSPF routes, but i get a problem.
== > 6.41.3 Router Server
OpenVPN server:
Local Address 172.16.0.1
Netmask 16
IP pool 172.16.0.2-172.16.254.254
OpenVPN connected successfully, but OSPF get errors in log:
route,ospf,info Discarding Hello packet: mismatch in network mask
route,ospf,info mine=255.255.0.0
route,ospf,info remote=255.255.255.255
route,ospf,info source=172.16.0.1
I think this is a bug, because Local Address on ovpn server has netmask /32, at this time Network is /16.
For bugfix is need apply Netmask parameter to Local Address too.
I have the same problem on mikrotik 6.40.9 bugfixes, my other mikrotik routers with older ROS do not have this error, I had to switch to static route to work on this router. Is any way to fix this?
if you only need to connect MT devices, you could use another VPN technology like IPSec/L2TP.
I like MT very much, but their OpenVPN implementation is known to be rudimentary.
Just a thought, but there are 2 modes to set openvpn to, ethernet and ip. the ip setting creates a tun interface and will not allow the multicast to forward, ethernet on the otherhand creates a tap which does. If you are in ip mode, try setting the network-type to nbma and specify the peers, or change the openvpn mode from ip to ethernet.
If I am off base let me know as I do have not run into a situation where I need to run OSPF over OpenVPN
