6.9 released!
What’s new in 6.9 (2014-Jan-31 11:18):
*) lcd - added option to change the color-scheme;
*) updated bootloader firmware;
*) ppp: fixed RADIUS accounting;
*) ppp: fixed IPV6-Prefix assigning;
*) ppp: fixed dial-on-demand;
What’s new in 6.8 (2014-Jan-29 15:52):
*) bridge - default protocol-mode changed to RSTP for new bridges,
fixed bridge mac address changing when port (with lowest mac address) goes down
*) userman - improve startup time;
*) sstp client - support server name verification from certificate;
*) wireless - improved 11n and nv2 stability;
*) dhcp client - support interfaces in bridge;
*) dhcp - parse decimal strings and IP addreses in options value;
*) bgp - don’t show community ‘internet’ in BGP advertisements;
*) ipsec - enable hardware acceleration for aes-cbc + md5|sha1|sha256 aead on tilera cpus;
*) ospf - fixed checksum calculation for OSPFv3 AS-external-LSAs;
*) default configuration - changed dhcp server lease time to 10 minutes;
*) fixed port isolation on CRSs (bug introduced in v6.6);
*) smb - added support for SMB 2.002
*) timezone information updated;
*) ppp - fixed ppp bridging (did not work since v6.6);
*) improved speed of PPP, PPPoE, PPTP & L2TP on multicore routers;
*) address-list - fix crash when adding two identical address list entries (not allowed any more);
*) fixed multicast forwarding on CCRs;
*) firewall - improved address-type matcher, and added it for ipv6 aswell;
Simply push “Check for Updates” in your router,
or download from http://www.mikrotik.com/download
If I’m reading correctly, from now on any bridge I create will have RSTP enabled by default?
If that’s the case, I certainly hope the priority has been defaulted to F000 than as well. I can see problems with this implementation on xSTP enabled networks. IMO, this was fine the way it was before and should be a setting we choose to enable.
This is now working for me again. It would be nice however if the PPP interface added to the bridge didn’t show as ‘(unknown)’ in /interface bridge ports however. This did used to work a few version back.
Working fine on RB493G, RB751U-2HnD and OmniTIK UPA-5HnD with latest included boot firmware.
rb433 worked fine
GUI support for IPsec users, mode-cfg and policy groups/templates seems to have been added to both WinBox and WebFig. Why is it not mentioned in the ChangeLog?
Watchdog it’s enabled after upgrading by default, and my RB are going crazy rebooting after 5 minutes.
I tested 6.9 updating 3 RB:
RB750 (removed headers but first one)
while ( true ) do={ system resource cpu print ;delay  10}
 # CPU                                           LOAD         IRQ        DISK
 0 cpu0                                           26%          3%          0%
 0 cpu0                                            9%          2%          0%
 0 cpu0                                           36%          5%          0%
 0 cpu0                                            7%          3%          0%
 0 cpu0                                            9%          1%          0%
 0 cpu0                                            6%          2%          0%
 0 cpu0                                           19%          5%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                           36%          6%          1%
 0 cpu0                                           39%          5%         28%
 0 cpu0                                           52%          7%          0%
 0 cpu0                                           28%          4%          0%
 0 cpu0                                           11%          2%          0%
 0 cpu0                                           15%          2%          0%
 0 cpu0                                            8%          1%          0%
 0 cpu0                                           12%          2%          0%
 0 cpu0                                           13%          3%          0%
 0 cpu0                                            5%          1%          0%
 0 cpu0                                           11%          2%          0%
 0 cpu0                                            3%          2%          0%
 0 cpu0                                           11%          2%          0%
 0 cpu0                                            8%          4%          0%
 0 cpu0                                           11%          3%          0%
 0 cpu0                                           21%          4%         15%
on a RB711UA-2HnD
 # CPU                                           LOAD         IRQ        DISK
 0 cpu0                                           45%         43%          0%
 0 cpu0                                           45%         45%          0%
 0 cpu0                                           43%         42%          0%
 0 cpu0                                           42%         42%          0%
 0 cpu0                                           41%         40%          0%
 0 cpu0                                           42%         42%          0%
 0 cpu0                                           41%         41%          0%
 0 cpu0                                           45%         44%          0%
 0 cpu0                                           42%         42%          0%
 0 cpu0                                           40%         40%          0%
 0 cpu0                                           46%         46%          0%
 0 cpu0                                           39%         39%          0%
 0 cpu0                                           39%         39%          0%
 0 cpu0                                           43%         43%          0%
 0 cpu0                                           37%         37%          0%
 0 cpu0                                           38%         38%          0%
 0 cpu0                                           38%         38%          0%
 0 cpu0                                           44%         44%          0%
 0 cpu0                                           41%         41%          0%
 0 cpu0                                           41%         41%          0%
 0 cpu0                                           41%         41%          0%
 0 cpu0                                           40%         40%          0%
 0 cpu0                                           43%         43%          0%
 0 cpu0                                           40%         39%          0%
 0 cpu0                                           44%         43%          0%
 0 cpu0                                           36%         36%          0%
 0 cpu0                                           44%         44%          0%
 0 cpu0                                           45%         45%          0%
 0 cpu0                                           42%         42%          0%
 0 cpu0                                           40%         40%          0%
 0 cpu0                                           43%         43%          0%
 0 cpu0                                           42%         42%          0%
 0 cpu0                                           41%         41%          0%
 0 cpu0                                           38%         38%          0%
 0 cpu0                                           43%         43%          0%
on a 951-2n:
 # CPU                                           LOAD         IRQ        DISK
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                           11%         10%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            2%          0%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            9%          0%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            9%          9%          0%
 0 cpu0                                            1%          1%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            1%          1%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            0%          0%          0%
 0 cpu0                                            2%          1%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                           23%          0%          0%
 0 cpu0                                            2%          0%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            1%          0%          0%
 0 cpu0                                            0%          0%          0%
which is pretty fair, yet…
> system routerboard print
  current-firmware: [b]3.10[/b]
  upgrade-firmware: [b]3.10[/b]
> system resource print
                   uptime: 19m52s
                  version: 6.9
No system is supposed to work hard (all of them had a <5% CPU before upgrading).
Happening to anyone else?
Bye
Bug in ipsec phase 2 AES-256 on CCR??
I have updated our CCR1036-12G-4EM from 6.7 to 6.9.
Al was working fine except for a lot of our VPN tunnels.
The standard ipsec tunnels with AES-256 in phase 2 (proposal) all send packages but did not receive.
After changing from AES-256 to AES-128 they went fine. All SA where correct but only outbound data not inbound.
So I do think there is a bug in the AES-256 implementation.
The other side of the tunnels were no Mikrotik devices but for example a SonicWall SRA 3500.
After changing from AES-256 to AES-128 in Phase 2 things were working OK. Also the tunnels seem much (factor 2x).
Hi, SMB not working well …
can’t access to shared folder, windows show me “not permision for this folder…”
I also still have high “management” CPU usage on the profiler (5 to 8%) while idle. Doesn’t happen on my 2011s.
There is nothing to stop one thing rather than another does not run from one of the version, I offered here that do not could be Denial of Service thing to develop in.
However, the increase in the cpu, why this version of the RB2011UAS-the 2Hnd-IN for more than a RB951-AN on this.
Nonsense
I do not want to cash out ahead of a new router for a new version if the blow goes just after the
sxt not accesible after upgrade
Hm thats interesting you know cos after upgrade (from 6.5) on two RB433AH address list was empty - can u check if this is a case
Lite5
Upgrade 6.7 → 6.9
18:05:50 system,error,critical System rebooted because of kernel failure
the device works
and
jan/02/1970 01:00:20 wireless,info xx:xx:xx:xx:xx:CE@wlan1 established connection on > 5500000> , SSID moja_siec
After upgrade SXT 5HnD from 6.7 to 6.9 graph lines (Rx signal/Tx signal )is not rendering at index page.
I have 2 SXT’s, configured in briged mode, but none of them rendering graph lines!
In first SXT with wireless bridge mode, there is no ‘wireless’ section at all.
Check this please.
Upgraded the following routerboards to 6.9 + firmware (a few of each): rb751u-2hnd, rb751g-2hnd, rb711u-2hnd, rb951g-2hnd, rb800, rb493g, rb2011uas-rm, rb450g
no issues so far … upgrade went smooth …
JF
From the looks of things, would yalls say that for what it’s worth…6.9 is a pretty good release with minimal bugs?
I downloaded it but I haven’t deployed it yet. From the posts here, it seems that this release is a good release.
Nice!
6.9 installed smoothly on the Dell 1950, with LSI / Perc6i (2 x 15K drives) and onboard Broadcom NIC’s. I have not been able to thoroughly test many functions, but so far it looks very good. I put a 1GB file on it, and then FTP downloaded at 650 Mb/s.
The only odd behaviour I’ve noticed so far, is that it will not reboot on command, via winbox.
Dean
(Yakco)
Really? Seriously? :confused:
