6 Lines 5 are load balancing -need the last one for https
Can any one help me on this one. I have 6 lines and i have manage to set up load balancing on five of them, but my problem is the 6’th line, I have to set it up for Https, voip, and secure mail, but it doesn’t want to work…
/ip firewall address-list
add address=10.2.0.0/24 comment="" disabled=no list=local
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=yes \
    protocol=icmp
add action=accept chain=input comment="default configuration" \
    connection-state=established disabled=yes in-interface=ether1-gateway
    connection-state=related disabled=yes in-interface=ether1-gateway
add action=drop chain=input comment="default configuration" disabled=yes \
/ip firewall mangle
add action=add-src-to-address-list address-list=third address-list-timeout=\
    30s chain="mark new unseen" comment="" disabled=no nth=5,3
add action=add-src-to-address-list address-list=first address-list-timeout=\
    30s chain="mark new unseen" comment="" disabled=no nth=5,1
add action=add-src-to-address-list address-list=second address-list-timeout=\
    30s chain="mark new unseen" comment="" disabled=no nth=5,2
add action=add-src-to-address-list address-list=fourth address-list-timeout=\
    30s chain="mark new unseen" comment="" disabled=no nth=5,4
add action=add-src-to-address-list address-list=seen address-list-timeout=30s \
add action=jump chain="mark new unseen" comment="" disabled=no jump-target=\
    "mark connection"
add action=mark-connection chain="mark connection" comment="" disabled=no \
    new-connection-mark=first_conn passthrough=yes src-address-list=first
    new-connection-mark=second_conn passthrough=yes src-address-list=second
    new-connection-mark=third_conn passthrough=yes src-address-list=third
    new-connection-mark=fourth_conn passthrough=yes src-address-list=fourth
    new-connection-mark=fifth_conn passthrough=yes src-address-list=fifth
add action=mark-routing chain="mark connection" comment="" connection-mark=\
    first_conn disabled=no new-routing-mark=first passthrough=no
    second_conn disabled=no new-routing-mark=second passthrough=no
    third_conn disabled=no new-routing-mark=third passthrough=no
    fourth_conn disabled=no new-routing-mark=fourth passthrough=no
    fifth_conn disabled=no new-routing-mark=fifth passthrough=no
add action=mark-routing chain=prerouting comment="" connection-mark=\
    first_conn disabled=no new-routing-mark=first passthrough=no \
    second_conn disabled=no new-routing-mark=second passthrough=no \
    third_conn disabled=no new-routing-mark=third passthrough=no \
    fourth_conn disabled=no new-routing-mark=fourth passthrough=no \
    fifth_conn disabled=no new-routing-mark=fifth passthrough=no \
add action=jump chain=prerouting comment="" connection-state=new disabled=no \
    jump-target="mark connection" src-address-list=local
    jump-target="mark new unseen" src-address-list=local
add action=mark-routing chain=prerouting comment=\
    " Route HTTPS traffic to ECMP" disabled=yes dst-port=443,444 \
    new-routing-mark=ecmp-https-route passthrough=yes protocol=tcp
add action=jump chain=prerouting comment=Https connection-state=new disabled=\
    yes jump-target=tcp-services protocol=tcp src-port=443,444
add action=mark-connection chain=tcp-services comment=https disabled=yes \
    new-connection-mark=https passthrough=no protocol=tcp src-port=443,444
add action=mark-packet chain=prerouting comment=Https connection-mark=https \
    disabled=yes new-packet-mark=https passthrough=no
add action=mark-routing chain=prerouting comment=https disabled=yes \
    new-routing-mark=https packet-mark=https passthrough=no
add action=masquerade chain=srcnat comment="" disabled=no out-interface=\
    ether1-gateway
and the routes
add comment="Https Default Route" disabled=yes distance=1 dst-address=\
    0.0.0.0/0 gateway=A scope=30 target-scope=10
add comment=Default disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    B scope=30 target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    B routing-mark=first scope=30 target-scope=10
    C routing-mark=second scope=30 target-scope=10
    D routing-mark=fourth scope=30 target-scope=10
    E routing-mark=third scope=30 target-scope=10
    F routing-mark=fifth scope=30 target-scope=10
add comment="ECMP route for HTTP" disabled=yes distance=1 dst-address=\
    0.0.0.0/0 gateway=A routing-mark=ecmp-https-route scope=30 \
    target-scope=10
add comment=https disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=\
    A routing-mark=https scope=30 target-scope=10
Can any one help me on this one?
Maybe because all your rules for https are disabled?
Also be careful of the order, from first quick glance it appears you are selecting with nth rule to 5 different gateways then afterwards making rule for https, but already packets are selected by nth rules so it will not go out the gateway you wish, but one of the 5? Check the ordering of the rules and also when you use passthrough. I am not saying that you have it wrong, just suggesting you double check your rule logic and their ordering.
I have taken off passthrough on my https connection and now all my traffic is going through my https connection, what must i do? i also don’t undestand the nth rule, can you suggest a better way for doing this and can you give me an example please?
Maybe best if you read some more. Here is a good example to try to get idea of how nth rule works. It was changed in v3.x so if you find examples on internet be careful, it may be example for 2.9x!
http://wiki.mikrotik.com/wiki/NTH_in_RouterOS_3.x
Ok Thanks, I have looked at it. I Understand how nth work, but I am confused of how to do it in the right order.
For example: to select the HTTPS packets first, route it to the right gateway, and then select all the other packets with nth.
If you can help me on this one ill appreciate it.
OK, try to see if this helps.
http://wiki.mikrotik.com/wiki/NTH_load_balancing_with_masquerade_(another_approach)
I can’t help you any further as my time will cost you money! :frowning:
Maybe someone who does not mind working out a full written out answer for your requirement can help you for free. But sorry, I can’t.
