6 pppoe same gateway 3.0
Dear friends
l need help on how to do load balancing on 6 dsl with the same gateway.
Currently l have a mikrotik 3.20 on Piv with 3.0 ghz and 8 nic.
but any suggestion will be gladly welcome.
Interface routing will probably work for you.
can some one give me a sample configuration which l can work with.
I have the same situation with 4 pppoe. Can some one give me a sample configuration.
Thanks.
:frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning: :frowning:
same case with, is there any member here have the example configuration?
Go into ip routing and find “gateway interface option” expand it to a necessary number of boxies and choose all interfaces.
