hi
I have 6 public IPs can assign that to 1 ether (lan interface) , the IPs have the same gateway.
how can I do that?
thanks
hi
how can I do that?
thanks
Sure you can. Just add those ip addrs on that interface and you’re ok.
If these ip’s were from different subnets then it’d be a bit trickier, but now it’s as easy as it is..
I did that but did not work.
only one of the IPs work when I add the others IPs.
another thing … I have more than one l2tp (client not server) connection … can I assign each one of these l2tp connection to go through specific ether (lan interface), and if that possible how can I do that.
and thanks for reply taduikis.
