6 VLAN 1 WAN
Hello everyone
I am facing a huge challenge that has really locked me in and I really hope there are some who know how to get on with all the vlan on the web?
I need to make an excited network more simple.
Today, all sw cisco runs and each vlan has an independent linksys router that goes into a dmz zone and from there another router out on the net.
To save all these routers away would keg try to run an RB2011 and run all these vlan via 1 ether1 out on the net?
the network consists of 6 VLANs with a very large gap between IP Addresses.
I’m posting my config in high hopes for help so I can successfully replace tomorrow?
I have tried what my knowledge is but it is far from enough :frowning:
add name=bridge-vlan1
add name=bridge-vlan2
add name=bridge-vlan3
add name=bridge-vlan4
add name=bridge-vlan5
add name=bridge-vlan10
add name=bridge-vlan999
/interface vlan
add interface=ether2 name=vlan1-ether2 vlan-id=1
add interface=ether3 name=vlan3-ether3 vlan-id=3
add interface=ether4 name=vlan1-ether4 vlan-id=1
add interface=ether4 name=vlan2-ether4 vlan-id=2
add interface=ether4 name=vlan3-ether4 vlan-id=3
add interface=ether4 name=vlan4-ether4 vlan-id=4
add interface=ether4 name=vlan5-ether4 vlan-id=5
add interface=ether4 name=vlan10-ether4 vlan-id=10
add interface=ether5 name=vlan1-ether5 vlan-id=1
add interface=ether5 name=vlan2-ether5 vlan-id=2
add interface=ether5 name=vlan3-ether5 vlan-id=3
add interface=ether5 name=vlan4-ether5 vlan-id=4
add interface=ether5 name=vlan5-ether5 vlan-id=5
add interface=ether5 name=vlan10-ether5 vlan-id=10
add authentication-types=wpa2-psk eap-methods="" management-protection=\
    allowed mode=dynamic-keys name=test1 supplicant-identity="" \
    wpa2-pre-shared-key=xxxxxxxxxx
    allowed mode=dynamic-keys name=test2 supplicant-identity="" \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge \
    security-profile=test1 ssid=test1 wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=D6:CA:6D:0A:55:AB \
    master-interface=wlan1 multicast-buffering=disabled name=wlan2 \
    security-profile=test2 ssid=test2 vlan-id=3 wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
/interface vlan
add interface=wlan1 name=vlan1-wlan1 vlan-id=1
add interface=wlan2 name=vlan3-wlan2 vlan-id=3
add disabled=no interface=bridge-vlan10 name="DHCP VLAN10 Mangement"
add name="VLAN3 test3" ranges=192.168.0.2-192.168.0.254
add name="VLAN1 test1" ranges=192.168.1.2-192.168.1.254
add name="VLAN2 test2" ranges=172.16.0.2-172.16.0.254
add name="VLAN4 test4" ranges=10.10.0.2-10.10.0.254
add name="VLAN5 HOTSPOT" ranges=10.20.7.2-10.20.7.254
add name="VLAN10 Mangement" ranges=10.5.0.2-10.5.0.254
add address-pool="VLAN2 test2" disabled=no interface=bridge-vlan2 name=\
    "DHCP VLAN2 test2"
add address-pool="VLAN4 test4" disabled=no interface=bridge-vlan4 name=\
    "DHCP VLAN4 test4"
add address-pool="VLAN5 HOTSPOT" disabled=no interface=bridge-vlan5 name=\
    "DHCP VLAN5 HOTSPOT"
add address-pool="VLAN1 test1" disabled=no interface=bridge-vlan1 name=\
    "DHCP VLAN1 test1"
add address-pool="VLAN3 test3" disabled=no interface=bridge-vlan3 name=\
    "DHCP VLAN3 test3"
add bridge=bridge-vlan1 interface=vlan1-ether5
add bridge=bridge-vlan2 interface=vlan2-ether5
add bridge=bridge-vlan3 interface=vlan3-ether5
add bridge=bridge-vlan4 interface=vlan4-ether5
add bridge=bridge-vlan5 interface=vlan5-ether5
add bridge=bridge-vlan10 interface=vlan10-ether5
add bridge=bridge-vlan1 interface=vlan1-ether4
add bridge=bridge-vlan2 interface=vlan2-ether4
add bridge=bridge-vlan3 interface=vlan3-ether4
add bridge=bridge-vlan4 interface=vlan4-ether4
add bridge=bridge-vlan5 interface=vlan5-ether4
add bridge=bridge-vlan10 interface=vlan10-ether4
add bridge=bridge-vlan3 interface=ether3
add bridge=bridge-vlan1 interface=ether2
add bridge=bridge-vlan3 interface=wlan2
add bridge=bridge-vlan1 interface=wlan1
add bridge=bridge-vlan5 interface=wlan3
add address=10.5.0.1/24 interface=bridge-vlan10 network=10.5.0.0
add address=10.10.0.1/24 interface=bridge-vlan4 network=10.10.0.0
add address=192.168.1.1/24 interface=bridge-vlan1 network=192.168.1.0
add address=172.16.0.1/24 interface=bridge-vlan2 network=172.16.0.0
add address=192.168.0.1/24 interface=bridge-vlan3 network=192.168.0.0
add address=10.20.7.1/24 interface=bridge-vlan5 network=10.20.7.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.5.0.0/24 dns-server=10.5.0.1 gateway=10.5.0.1
add address=10.10.0.0/24 dns-server=10.10.0.1 gateway=10.10.0.1
add address=10.20.7.0/24 dns-server=10.20.7.1 gateway=10.20.7.1
add address=172.16.0.0/24 dns-server=172.16.0.1 gateway=172.16.0.1
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
add distance=1 gateway=ether1
/system identity
set name="Router"
Hmm my DMZ was worng so the only thing to add to the code is one more route = 0.0.0.0/0 with gateway ether1
All wlan, dhcp hotspot and trunk on port 4 and 5 to cisco are working and all vlan have only ether1 as wan.
Cheers
Jimmy
hmm i do not understand this?
I have work on the internet with these settings with no problems but now i have no internet on any vlan anymore ??
i have go back and back and forward again but i can’t get it to work, so i rely search for help to get this to work..
Hope someone network people who will take up this challenge..
Cheers
Jimmy
Denmark? Copenhagen?
Hi Jimmy, what mikrotik product are you using?
Can you provide a diagram of your network (always helpful to clear up requirements).
Also post a complete config (just need to change public IP facing addresses)
/export hide-sensitive file=yourconfigaug28
Hi Anav
Of cause I will post a pic and configure file.
I wars working on last night and find one small error on a vlan in the config so I have sad it up in the company and it is working :slight_smile:
I will still post config and pic to share with other.
I no there is many guid with multi subnet and one wan but I cut ten find any with multi vlan and dhcp on all vlan and one wan and of cause working with cisco.
I am out of town the next 2 dates and after that I will post the pic and config.
Cheers
Jimmy
Send from iPhone
