What is the new command for alignment in 60 GHz gear when using RouterOS v7.2.3 or higher?
The old commands don’t seem to work, and the website isn’t updated the reflect v7+.
Thank you, Chris
Thank you, Chris
Works for me on Cube 60Pro with 7.2.3
I made a mistake in my command. It is actually working as expected. The correct command is:
/interface/w60g/align wlan60-1
