60 Ghz link shows constant traffic
I have a 60GHZ link from the barn to an out building. Two Mikrotik wAP 60Gs configured as bridge and station. Link is solid and SpeedTest max out the ISP..
However… when I check the status… there seems to be 18Megs of traffic between the Wireless Interfaces of the 2 points. But it doesn’t come from or Go anywhere else?
Any ideas?
I hit align on the transmitter side. Connection dropped. When I turned off align… unit reconnected. 18 M is gone.
I occasionally see that as well, but closer to 400-600kbps to all clients. It seems to me like it’s some kind of broadcast or ARP traffic, but I can’t see anything in other systems indicating that it’s a problem.
Its it stuck @18.1MB? I use these devices at a site and the traffic seems to be stuck and does not change
It seemed to stay right between 17 and 18 M.
