60G flapping after upgrade
Hi All,
I have upgraded a 60G bridge from 7.3.1 to 7.5. First I upgraded the station bridge all was fine, After that i upgraded the station, and the link is flapping.
As The configuration was not changed I assume the 7.5 needs more settings.
Station:
set [ find default-name=ether1 ] loop-protect=on loop-protect-disable-time=1m
/interface w60g
set [ find ] disabled=no mode=bridge name=wlan60-1 password=XXX put-stations-in-bridge=bridge ssid=WWB
/interface vlan
add interface=bridge name=vlam-mgmt vlan-id=21
/interface w60g station
add mac-address=18:FD:74:24:CB:DF name=wlan60-station-1 parent=wlan60-1 put-in-bridge=bridge remote-address=18:FD:74:24:CB:E1
Station Bridge
/interface w60g
set [ find ] disabled=no mode=station-bridge name=wlan60-1 password=XXX ssid=WWB
/interface vlan
add interface=bridge name=vlan_mgmt vlan-id=21
I am thinking of downgrade to 7.3.1
Any other idea?
Bug in 7.5 firmware. We are waiting for a fix…
This bug is fixed in 7.6 beta
Thanks for both,
I am looking for 7.6 stable. Does it make sense to upgrade the firmware, too or the RouterOS enough.
I usually upgrade only the OS.
Br Peter
Im on 60Ghz on 7.4.1 after that there is no improvement to those devices… I do not want upgrade every month and risk bricking devices which are on the roof. I advice 7.4.1 on 60Ghz and 7.5 on the main router.
I do upgrade firmware always, but not sure if this is neccesary. I think you could avoid some problems.
