I am wondering if anyone else has ran into this problem with monitoring 60ghz stations?
From https://wiki.mikrotik.com/wiki/Manual:Interface/W60G
For main interfaces:
1.3.6.1.4.1.14988.1.1.1.8.1.3.1 string SSID
1.3.6.1.4.1.14988.1.1.1.8.1.12.1 integer RSSI
1.3.6.1.4.1.14988.1.1.1.8.1.13.1 gauge32 PHY rate
station interfaces will be numbered forward starting from this point
1.1.1.8(+1).1.6.1 integer Frequency
etc
The snmpwalk shows the first station connected but nothing about the rest. How are you guys monitoring these ptmp setups on 60ghz if only the first client is visible in snmp?
Thx,
Sam
