60Ghz WAP60G-AP multi-client latency
Hi All,
With three LHG 60Ghz clients connected to an AP and practically no traffic, we see latency jumping between ~1-15ms. Distance 120m,150m,175m. With a single client only, latency is ~1 ms.
Anything can be done to stabilize the performance ? We would prefer a stable 10ms latency than 1-15ms jumping one.
64 bytes from x.x.225.132: icmp_req=59 ttl=62 time=0.778 ms
64 bytes from x.x.225.132: icmp_req=60 ttl=62 time=4.85 ms
64 bytes from x.x.225.132: icmp_req=61 ttl=62 time=0.784 ms
64 bytes from x.x.225.132: icmp_req=62 ttl=62 time=5.01 ms
64 bytes from x.x.225.132: icmp_req=63 ttl=62 time=0.727 ms
64 bytes from x.x.225.132: icmp_req=64 ttl=62 time=3.78 ms
64 bytes from x.x.225.132: icmp_req=65 ttl=62 time=0.795 ms
64 bytes from x.x.225.132: icmp_req=66 ttl=62 time=12.1 ms
64 bytes from x.x.225.132: icmp_req=67 ttl=62 time=0.820 ms
64 bytes from x.x.225.132: icmp_req=68 ttl=62 time=0.842 ms
64 bytes from x.x.225.132: icmp_req=69 ttl=62 time=9.24 ms
With single client:
64 bytes from x.x.225.133: icmp_req=175 ttl=62 time=0.725 ms
64 bytes from x.x.225.133: icmp_req=176 ttl=62 time=0.815 ms
64 bytes from x.x.225.133: icmp_req=177 ttl=62 time=0.798 ms
64 bytes from x.x.225.133: icmp_req=178 ttl=62 time=0.942 ms
64 bytes from x.x.225.133: icmp_req=179 ttl=62 time=0.825 ms
64 bytes from x.x.225.133: icmp_req=180 ttl=62 time=0.759 ms
64 bytes from x.x.225.133: icmp_req=181 ttl=62 time=0.918 ms
64 bytes from x.x.225.133: icmp_req=182 ttl=62 time=2.11 ms
6.44beta28 makes significant latency/jitter improvements. Thanks Mikrotik :slight_smile:
And speed improvements. Especially fixing an issue with having more than 3 stations connected.
We’re eagerly awaiting a stable release for mass deployment.
great news thanks
