60ghz with 2.5g interface
As the 802.11ay has a wireless speed greater then 1gbps and is half duplex (we can see this as we can see higher then 1gbps speeds between radios with a speed test) I was wondering if mikrotik had any plans of releasing newer versions of their hardware with a 2.5g port available to make use of the bandwidth? We are facing challenges of needing to go higher then 1gbps for some of our links
