Hey y’ all.
Our ISP has started to support IPv6m which is awesome, and I was hoping to give it a try.
There only seems to be one issue.
They serve the settings over 6rd, which is based on 6to4. Now 6to4 is supported in MikroTik, but 6rd doesn’t seem to be.
I’ve contacted the ISP on other ways to set it up, and they claim DHCP should send the settings just fine.
Well, i’m getting all my IPv4 settings fine over DHCP. But my DHCPv6 keeps searching and not finding anything..
Settings can be found here https://www.on.nl/klantenservice/diensten/internet/ipv6/
Is there any way to set this up in RouterOS?
I’ve tested this is two diffrent situations with RouterOS, same result.
Both are FTTH connections, same ISP, same IPv4 Subnet. Provider claims is should work natively by DHCPv6, but I’ve go no clue so far.
Can anyone help me out with this? ![]()
Thanks!
