I’m trying to set up a 6to4 tunnel via Hurricane Electric’s Tunnel Broker, but I’m having trouble understanding why the assigned IPv6 addresses are showing up as Invalid.
My ISP provides a static IPv4 address via DHCP as a service:
/ip dhcp-client print
Columns: INTERFACE, USE-PEER-DNS, ADD-DEFAULT-ROUTE, STATUS, ADDRESS
# INTERFACE USE-PEER-DNS ADD-DEFAULT-ROUTE STATUS ADDRESS
;;; defconf
0 ether1 yes yes bound 95.31.176.92/30
After configuring the 6to4 tunnel, the IPv6 addresses appear with the Invalid flag:
/interface 6to4 add comment="Hurricane Electric IPv6 Tunnel Broker" disabled=no local-address=95.31.176.92 mtu=1280 name=sit1 remote-address=216.66.80.30
/ipv6 route add comment="" disabled=no distance=1 dst-address=2000::/3 gateway=2001:470:1f0a:684::1 scope=30 target-scope=10
/ipv6 address add address=2001:470:1f0a:684::2/64 advertise=no disabled=no eui-64=no interface=sit1
Interface status looks okay:
/interface 6to4 print
Flags: R - RUNNING
Columns: NAME, MTU, ACTUAL-MTU, LOCAL-ADDRESS, REMOTE-ADDRESS, DSCP
# NAME MTU ACTUAL-MTU LOCAL-ADDRESS REMOTE-ADDRESS DSCP
;;; Hurricane Electric IPv6 Tunnel Broker
0 R sit1 1280 1280 95.31.176.92 216.66.80.30 inherit
But the IPv6 address is marked as invalid:
/ipv6 address print
Flags: I - INVALID; D - DYNAMIC; G - GLOBAL, L - LINK-LOCAL
Columns: ADDRESS, INTERFACE, ADVERTISE
# ADDRESS INTERFACE ADVERTISE
0 IDL fe80::3:5f1f:b07a/64 sit1 no
1 I G 2001:470:1f0a:684::2/64 sit1 no
The default route also shows as inactive:
/ipv6 route print
Flags: I - INACTIVE; s - STATIC
Columns: DST-ADDRESS, GATEWAY, ROUTING-TABLE, DISTANCE
# DST-ADDRESS GATEWAY ROUTING-TABLE DISTANCE
0 Is 2000::/3 2001:470:1f0a:684::1 main 1
IPv6-in-IPv4 (protocol 41) is explicitly allowed in the firewall:
/ip firewall filter print
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; Allow Protocol 41 for 6to4 Tunnel
chain=input action=accept protocol=ipv6-encap
1 chain=output action=accept protocol=ipv6-encap
Any ideas why the address and route remain Invalid and Inactive? Is there something missing in the configuration or a MikroTik-specific requirement I’m overlooking?
> /system/routerboard/print
routerboard: yes
board-name: hAP ac lite
model: RB952Ui-5ac2nD
serial-number: 71AF053C2238
firmware-type: qca9531L
factory-firmware: 3.36
current-firmware: 7.20.6
upgrade-firmware: 7.20.6
Thanks in advance!
