Issue: CPU frequency not shown (ie. is empty)
Version number (if the issue is upgrade related, specify which version was installed before as well):
RouterOS 7.0 beta5
Previous version was: 6.46.5 (stable) -
Router’s model:
CRS326-24G-2S+RM -
Steps to reproduce the issue:
see attached screenshot -
Configuration export (use ‘/export hide-sensitive’ command):
[admin2@MikroTik] > /system/export hide-sensitive
# apr/19/2020 10:47:57 by RouterOS 7.0beta5
# software id = QXVZ-VVPX
# model = CRS326-24G-2S+
# serial number = 94550B3F52F5
/system clock
/system clock manual
set time-zone=+01:00
/system ntp client
set enabled=yes
/system ntp client servers
add address=192.168.254.254
/system routerboard settings
set boot-os=router-os
- Any additional information that would help troubleshoot the issue (screenshots, debug logs, etc.):
Also in the following output the CPU-frequency is not shown (in v6 there was such a CPU-frequency line)
[admin2@MikroTik] > /system/resource/print
uptime: 35m25s
version: 7.0beta5 (development)
build-time: Feb/07/2020 11:56:32
factory-software: 6.44
free-memory: 461.5MiB
total-memory: 512.0MiB
cpu: ARMv7
cpu-count: 2
cpu-load: 0%
free-hdd-space: 3152.0KiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 41
write-sect-total: 4470
bad-blocks: 0%
architecture-name: arm
board-name: CRS326-24G-2S+
platform: MikroTik
