Hello!
I want to use several mikrotik devices connected over wireguard to the same server, with ospf.
I created wireguard server on centos 7, with address 192.168.89.1/24 and bird as ospf service.
Then I connect mikrotik over wireguard. Everything is good here.
If I set AllowedIPs = 0.0.0.0/0 then ospf just works over multicast in one peer mode,
but this does not work if more then one peer.
So I limited this on server side to AllowedIPs = 192.168.89.2/32.
Any traffic passes over wireguard then but multicast.
So I need unicast:
/routing ospf instance
add name=ospf-instance-1 router-id=192.168.89.2
/routing ospf area
add area-id=0.0.0.1 instance=ospf-instance-1 name=ospf-area-1
/routing ospf interface-template
add area=ospf-area-1 networks=192.168.89.0/24 priority=0 type=nbma
/routing ospf static-neighbor
add address=192.168.89.1%wireguard1 area=ospf-area-1 poll-interval=5s
And here problem starts.
As I can see from tcpdump on server side mikrotik does not send hellos into wireguard interface, I see only hellos from bird:
tcpdump -n -i wg0 host 192.168.89.2
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on wg0, link-type RAW (Raw IP), capture size 262144 bytes
13:57:56.341322 IP 192.168.89.1 > 192.168.89.2: OSPFv2, Hello, length 44
13:58:16.341272 IP 192.168.89.1 > 192.168.89.2: OSPFv2, Hello, length 44
13:58:36.341131 IP 192.168.89.1 > 192.168.89.2: OSPFv2, Hello, length 44
If I connects from my desktop as second peer using FRR then everything works just fine:
interface wg0
ip ospf network non-broadcast
ip ospf priority 0
router ospf
ospf router-id 192.168.89.3
network 192.168.89.0/24 area 1
neighbor 192.168.89.1
ospfd# show ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface RXmtL RqstL DBsmL
10.1.1.5 128 Full/DR 39.863s 192.168.89.1 wg0:192.168.89.3 0 0 0
ospfd#
Could you tell me what is wrong here? Looks like mikrotik bug for me…
Thank you!
