Hi all
I don’t know if this is a bug or by design. When you add a comment, whether at a port, bridge, vlan, etc The comment shows in a separate row above the item with 3 semi colons before the comment. if you comment all the ports in a 48 port switch, that makes for an awful convoluted messs. Should the comment not show up in a column beside the device you are comenting on. I had been using swos up until recently and it definitely has a better commenting scheme. If this isn’t a bug then maybe it can be a feature request.
Thanx
