(WARNING: TO AVOID TRIGGERING SOME, KNOW THAT I’M RUNNING WAY MORE THAN 3 CAPS)
In all seriousness is anyone else having this issue…I’m not seeing any type of interface stats (TX,RX ,etc) on the CAPSMAN (wifi) controller when I monitor-traffic for any CAPax devices. The CAPS are passing traffic and the SSIDs are working as intended and using the correct VLANS. I can see traffic as expected on individual interfaces when ssh’d into the CAPax device but zero stats on the controller. My CAPSMAN (wireless) controller (same device) running CAPacs are displaying stats as expected.
I try to keep up on the forums (the best anyone can) and why that issue always seems to be a hot topic, I don’t know but I had to throw it in but only out of a little humor.
It might if CAPs collect the stats and report it to manager. As we all know, manager, who doesn’t know what subordinates are doing, can’t do his job efficiently. Right?
FWIW just tested in my lab setup (I got a Hex setup with both capsman environments and then AX2 and mAP as APs):
Old capsman with local forwarding → zero counters on interfaces visible on capsman controller. They do show on local AP device.
Local forwarding disabled and bridge defined in datapath (a.k.a. capsman forwarding) → counters start to flow on capsman controller. Nothing visible anymore on local device.
It’s also noticable when you see the interface line itself on the local AP device.
local forwarding → interface line is black
capsman forwarding → interface line is greyed out. Nothing to see there.
So my conclusion is that wave2 behavior is exactly the same as it was in the past for that local forwarding part.
With a not so insignificant minor detail that capsman forwarding does not exist anymore (yet ?) in wave2-environment. Only local forwarding remains.
Only way I can think of to sort-of “recreate” this local forwarding is to make use of EOIP and force all data to run over there.
AP only able to see capsman controller, nothing else.
Setup EOIP between AP and controller (which is possible since controller can be reached, nothing else)
Attach EOIP to bridge, default route for AP going over that EOIP link.
Result: All AP traffic visible on capsman controller.
