Hi
i have just installed 7.14.2 onto my mikrotik router and i want to use it for internet access.
As i have my mailserver at home i have some NAT what i also want to hairpin.
i used the quickset on the WEB IF to make the initial config including the NAT i needed.
And then i wanted to add HAIRPIN. I watched this video from mikrotik: https://www.youtube.com/watch?v=1I5FywY6opQ
I also tried several other proposals found via google. But nothing worked.
Is it possible that the one or other action from the default config plays games with me ?
Below you find the config and the part in question in bold.
Ideas are highly appreciated.
P.S.: I didnt test any other version till now. The mikrotik is replacing another router so i cannot comment if other versions work.
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment=submission dst-port=587 in-interface-list=WAN protocol=tcp to-addresses=10.21.21.244 to-ports=587
add action=dst-nat chain=dstnat comment=smtp dst-port=25 in-interface-list=WAN protocol=tcp to-addresses=10.21.21.244 to-ports=25
add action=dst-nat chain=dstnat comment=imaps dst-port=993 in-interface-list=WAN protocol=tcp to-addresses=10.21.21.244 to-ports=993
add action=masquerade chain=srcnat comment=“hairpin : mikrotik youtube” dst-address=10.21.21.244 log=yes log-prefix=HAIRPIN: out-interface=bridge protocol=tcp src-address=10.21.21.0/24
# 2024-03-28 17:10:04 by RouterOS 7.14.2
# software id = 0P78-XXXX
# model = RB3011UiAS
# serial number = xxx
add admin-mac=E4:8D:8C:0A:41:B0 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=xxxxx@t-online.de
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.21.21.90-10.21.21.199
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" disabled=yes disabled=yes name=zt1 port=9993
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
set udp-timeout=10s
add address=10.21.21.254/24 comment=defconf interface=bridge network=10.21.21.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=10.21.21.0/24 comment=defconf dns-server=10.21.21.254 gateway=10.21.21.254 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=10.21.21.254 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="hairpin : mikrotik youtube" dst-address=10.21.21.244 log=yes log-prefix=HAIRPIN: out-interface=bridge protocol=tcp src-address=10.21.21.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
/system identity
set name=RB3011
/system note
set show-at-login=no
/system package update
set channel=testing
/system routerboard settings
set auto-upgrade=yes silent-boot=yes
/tool mac-server
/tool mac-server mac-winbox
