7.16 firewall issues
hello, i am daniel
port forwarding not working on 7.16 or 17? tried everything for port 12349
on 6 was dns not working with pppoe. so am i right did i configure it right?
please help. thank you.
# 2024-12-14 20:09:48 by RouterOS 7.17rc3
# software id = P6FU-3L0G
# model = RB4011iGS+
# serial number = <removed>
add admin-mac=08:55:31:E8:DA:D9 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
set 1 name=serial1
/system logging action
add email-to= name=email target=email
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface ovpn-server server
add mac-address=FE:03:CB:2D:87:9C name=ovpn-server1
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.1.102 mac-address=B4:2E:99:33:26:61
add address=192.168.1.105 mac-address=D8:43:AE:22:73:A8
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan type=A
add action=accept chain=forward dst-port=12349 protocol=tcp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input dst-port=12348 protocol=tcp src-port=""
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=192.168.1.105 dst-port=12349 in-interface-list=WAN protocol=tcp to-addresses=192.168.1.105 to-ports=12349
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
/ip service
set telnet address=192.168.1.0/24 disabled=yes
set ftp address=192.168.1.0/24 disabled=yes
set www address=192.168.1.0/24
set ssh address=0.0.0.0/0 port=12348
set www-ssl address=192.168.1.0/24 disabled=no
set api address=192.168.1.0/24 disabled=yes
set winbox address=192.168.1.0/24 disabled=yes
set api-ssl address=192.168.1.0/24 disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
/system identity
set name=
/system note
set show-at-login=no
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
remove destination address from redirect rule
destination address is the WAN address obtained from dhcp-client
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related hw-offload=yes
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment=“drop all else”
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
add action=dst-nat chain=dstnat in-interface-list=WAN dst-port=12349 protocol=tcp to-addresses=192.168.1.105
works great. thank you
