7.17.2 Webfig Bug
Bug: When using Webfig with 7.17.2 when you go to the main quickset page, the wifi and vpn passwords are displayed, even though the check box to hide them is checked by default. If you uncheck and then recheck them, the passwords are disguised.
A related question: If I create a test user on the router that only has the group attributes of “local, user, read, winbox, web” I would have expected that it would not be possible to display or see items like passwords since “sensitive” is not allowed. What purpose does sensitive serve in this context. The documentation says is does not allow export of sensitive information, but it seems silly to not block sensitive information via webfix or winbox in this case. Am I missing something?
The current version is 7.17.2, please try that and see if the issue still happens
Problems still exist in 7.17.2. Mikrotik support responded to a bug report saying:
Thank you for contacting MikroTik Support.
First bug you are writing about is fixed and will be available in newer versions. Now it is also available in testing version 7.18beta5.
About second bug. This is a known issue and we are working on fixing it. Unfortunately, I cannot give an ETA when it will be fixed.
Normis, note my report said I was using 7.17.2. What is the name of your cat? :slight_smile:
