You cannot set distance for output routes, because distance is local to the router. You can set other parametrer like ospf metric or route tag which can then be used to match specific routes and adjust the distance on the remote routers input.
I haven’t tested this myself yet but reading @mrz’s response I’m curious. Since setting distance is conceptually invalid in this case, is the result that the entire filter clause fails to be applied? I would naïvely expect that it would just ignore the irrelevant set statement. It seems reasonable that it would still do the match, set the OSPF metric, set the OSPF type, and then accept the route.
@mrz are you just pointing this out for @tommyd’s benefit or are you saying that this is why no routes are being matched at all?
In the original post there is no mention that prefix is not matched at all. Setting distance in the output will not fail to match anything, rule in the first post will still apply ospf ext type and ext metric.
