Just wanna double check before I upgrade, after the reports in this thread that some RB5009 user lost access to the device after the upgrade to 7.23.7 (and I also seen something similar in other thread related to CRS) - is there or is there not a confirmed issue with this version and RB5009? The last thing I want is having to netinstall just because of some bug. I checked any my device is NOT flagged in the device mode print, if this was the issue.
Why do you think it's "a 5009 issue"?
AFAIK some of these 5009 were compromised and "flagged". That was an "issue".
Always have a backup (text one or binary) to be able to revert to working state "in case of something".
Post here: 7.23.7 [long-term] is released! - #67 by LordNikkon
But I admit, it is only 1 occurrence. And of course I do backups before every update, but still, having to netinstall and restore the backup takes time I would like to avoid. But I probably worry too much.
The "situation" you pointed to could had happend as there were cumulated "artefacts" of LordNikkon's router configuration that got exposed during that particular upgrade.
Good that you think in advance but "sh*t" could always happen, eg. power outgage or just spike during upgrade that kills the device.
Read:
I configured a nRAY 60G running 7.23.7 from scratch. /exportshows:
/interface w60g
set *2 disabled=no frequency=64800 mode=bridge name=wlan60-1 put-stations-in-bridge=bridge1 region=no-region-set ssid=Link1
No idea why it shows *2, on 7.20.8 it showed:
/interface w60g
set [ find ] disabled=no frequency=64800 mode=bridge name=wlan60-1 put-stations-in-bridge=bridge1 region=no-region-set ssid=Link1
After upgrade to 7.23.7 on RB5009 I have lost SSD connected to USB.
In system/disks the "usb1-part1" does not show any info, everything is empty, and in "files" it says "read-only mountpoint", but does not show any files.
Anyone knows what was changed between 7.23.5 and 7.23.7 that might have caused it and how to make the disk visible to system again?
edit: after physically disconnecting and connecting the SSD it finally showed up. This never happened before during previous upgrades.
It's a bug. Spotted the same [find] replaced by *number artefact on Cube Pro 60G when they were upgraded from 7.21.5 to 7.23.5, not fixed in .6 or .7
This was an issue but not the issue for Romon.... apparently there were changes specific to the CRS100 series switches that broke Romon and still to be fixed as at 16/10/2026.
The "system identity" issue has been fixed.
