7.23.8 [long-term] is released!
Before an upgrade:
Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.23.8 (2026-10-08):
  • console - fix console output of /system/identity/print being split into multiple lines (introduced in v7.23.6);
  • ethernet - improved stability when forcing unsupported link speed;
  • ipsec - fix IPsec tunnels not establishing when an address my-id is configured on the responder;
  • ospf - fix unset interface template parameters not being applied to interfaces;
  • quickset - fix the WAN interface being selected incorrectly;
  • system - improve stability (includes CVE-2026-84411, CVE-2026-103903);
  • system - stop the flash configuration store from growing on dynamic configuration changes;
  • wifi - fix malformed management frame information elements advertising availability of multiple 6GHz APs;
  • wifi - update radio regulatory information;
To upgrade, click Check For Updates under System/Packages menu and select the long term Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
does this fix the issues when connecting dude and romon to mipsbe devices ?
I've updated two mipsbe devices and Dude still won't connect... so no...
tnx for confirming !
really sad that this is not fixed, so no upgrade for me ... (lots of mipsbe devices behind romon and on dude)
@strods
Pin, please
Till now only 1 CHR, all ok.
crs305's and a test haP-ax2 updated - no issues so far. Waiting a bit to do core routers . . . .
Upgrade from 7.23.7 on a crs309 and 317, no prob.
7.23.7 to 7.23.8 on hAPax2 - Ok.
But, the same error with dependencies for DNS (DoH) service.
The DNS service (DoH) starts approximately 10 seconds before the its linked interface (wan.ether1) is up.
As a result, the system generates unnecessary log errors.
Not a critical error, but...
This same bug has been recurring year after year.:neutral_face:
Have u reported that to their jira support via a ticket?
Make a step by step "guide" for them to replicate it so they can reproduce it and then you gonna have biggest chances of stuff being fixed, i personally had relatively quick responses 1-2 days in-between and most of my reports got fixed.
As i said million times, they do read the forums but not nearly as much as their support tickets.
Surely. :wink:
Deployed to all ROS devices - zero issues seen. (RB5009, CAP-ax, haP-ax2, CRS-305, haP lite, heX refresh)
After the update, the router (x86) switched to bridge mode (!!!).
After switching back to router mode, the router itself has internet access, but the connected devices do not.
Switching to the stable version helped.
Are people responsible for pinning topics on vacation again? :smirking_face:
There's been a lot of recent patches for a long term kernel.
No. Furthermore several other device type can't connect as dude agents, not only MIPSBE ones.
I've always had problems with Dude connecting to v7 CRS106 & CRS112 devices (going back to at least v7.14.3). Having upgraded some other devices from 7.23.5 to 7.23.8 the Cube 60 Pro (CubeG-5ac60ay) which is arm architecture has started exhibiting the same issue.
Possibly caused by marginal timing/timeout as the devices show a successful login from Dude but Dude status never progresses beyond connecting.
I know Dude isn't really supported any longer, but breaking connectivity from it when the supposed replacement is only just in alpha testing and missing many necessary features is not good.
I never had connectivity issues with dude, I use it for years. It misses some important features and I personally think it is a pitty that MT decided to stop support.
The new CMR is probably good for al new devices but a lot (and I mean a LOT) of devices in the wild will not be supported ...
but, stopping support might not lead to breaking existing connectivity, and certainly not in something MT calls LTS ..
Do you or anyone really have a lot of powerpc or smips based devices in production? smips is low cost thing like hap lite or hap mini. And powerpc like rb1100 are ancient as well.
It does.not work even on a RB3000 with an ARM processor. It's a bug.
happened on my hAPax3 too, the first reboot after the update result in DNS failed to proper setup it's upstream so network is not usable, cleared after next reboot, kind of nasty bug that hard to reproduce
