7.25.1 [stable] is released!
RB5009 and CRS310-8G-2S+ upgraded without issue.
hAP ax3 bricked after reboot... gonna try another power supply but I have low hopes, LED is solid blue, reset button doesn´t seem to do anything...
Check GitHub - mark99i/WinboxPatch: WinBox 3.43 for RouterOS 7.25+ · GitHub
I made it so that it works correctly in 7.24 (MT managed to break some fields), 7.25, and even CMR 7.26beta in CHR.
After updating from 7.25 to 7.25.1, the speed of my AP—which is managed via CAPsMAN—dropped drastically. Before the update, it was ~300 Mbps; afterwards, it was a maximum of 40 Mbps. Downgrading to 7.25 resolved the issue.
Hello @pe1chl, @AlexandruL,
Thank you for the reports. Since 7.25, /export orders entries by their dependencies, so some sections can appear in two blocks and /interface bridge port is now at the end. These exports import correctly.
We have also confirmed that a route with routing-table= can be exported before /ip vrf, which stops the import on a clean device. We have acknowledged the issue and will work on a fix.
And what about the MLAG issues that @DariuszWr reported?
Yes, we have few reports and work is ongoing on this issue.
Ok they will probably import correctly but it is so inconvenient when manually working through exports, to compare them between devices, and also when storing them in version control systems.
In fact I would appreciate it when /export would always order items within sections in some fixed ordering, not dependent on the order in which the items have been added. That happens for some sections (e.g. VLAN) but not for others (e.g. addresses).
That's exactly what I've said several times in the beta and RC threads when begging MikroTik to reconsider the change :(. I'm staying on 7.24.x while I still can to avoid this change.
I remamber you had located the cause of aproblem with Dude connections to mipsbe devices. Any news on when it might get fixed?
You mean in general for these routerboards? I have not used netinstall fo far.
No, I mean for those ARM-AC based boards with only 16Mb of storage where wifi-qcom-ac driver is being used.
It's common knowledge around here when using those devices with wifi-qcom-ac driver, it will be needed at some point in time to netinstall them again.
Public documentation regarding Objects, Attributes, and Relationships.
This issue—where different attribute types affect the export order—reminds me of a topic that has been brought up a few times here on the forum.
Given the new documentation style, I believe it would be highly beneficial for MikroTik to publish the types of relationships that exist between objects.
I imagine that @Amm0 (with its work on Rosetta and RESTRAML) and @jeffnasseri (with its work on mikrotik-mcp) might have a more well-informed perspective on this.
I believe that if "strong" and "weak" relationships were documented in an indexable format, it would not only reduce the frequency of these types of bugs but also help ensure that automation tools and AI-driven systems avoid creating incomplete configurations.
Your problem is the export is not really the configuration. And merely generated from the RouterOS binary store the actual config data, which follows the inner parts of winbox protocol. This is all internal on RouterOS when you run export, so predicting what form it will spit out (beyond brief, etc) is impossible. When you do an upgrade on the router, I'd imagine (but dunno), it's just migrating the raw "winbox blob" that actually the config, and never goes through the export/import things you see. So basically export is not WYSIWYG.
Now I get the problem, you diff exports, so these things do affect your operations. But there is no easy community fix to your problem. MikroTik does not document the guarantees around the "shape" of the export, other than it's a serious bug in the export did not import, but the ordering of the commands is up the internal process that converts "winbox blobs" to RouterOS syntax that work in user-mode. Even some offline parser of RouterOS script does not the "right" order and can merely represent the tree as a config produced it. And it that "right" order that's hard to define, and likely hard for MikroTik to assure be same accross version, especially if there are making bigger changes like CMR that likely does change the "winbox blobs" with the actual configuration.
The underlying problem is decade old: some RouterOS declarive config. MikroTik rejected NETCONF, YANG, or anything beyond TR069 which is limited and merely wraps "intrepretive" RouterOS scripts to fill in for the same amount of time....
So to solve your diff problem, MikroTik need to have some, for example, JSON output of the actual config state - an export is just a special script that's run - that was readable by the router as alternative to today's export/import which essentially, for example, wrap a lot of get for export to generate it, and then :execute on /import.
It surprises me that some sections are now being split, instead of being moved further down until all their dependencies have been resolved.
E.g. /ip route on my router now starts off with a number of static routes, then it ends and way further down a pppoe-client is defined and another /ip route section follows the routes that are defined to be via that pppoe-client.
I can understand that the routes cannot be set until that interface is known, but why not move the entire route definition down to below that point. In fact, what has happened in 7.25 relative to 7.24 is that the pppoe-client has been moved way down the export, it was near the beginning and this issue did not occur at all.
Hello. Upgrade from 7.25 to 7.25.1 on HAP BE LITE.
I get one weird thing on Wifi Bands (MLD with 2.4 and 5 Ghz) : all my devices, phones, laptops, only connect on 2.4Ghz band now. Before with 7.25 they were catching 5 Ghz band without issue.
I'm newbie with Mikrotik, so issue could be me (certainly is).
arp-accept=no means that the Interface does not accept gratuitous arp-messages. When a device announces an IP-to-MAC address mapping to the network without being explicitly asked (often used to update other devices' ARP caches when an IP moves or a device boots up).
This is mainly for preventing unauthorized or rogue devices on the network from poisoning or altering the router's ARP cache via unprompted ARP announcements.
So with "no" the router updates it's cache only if it asks for the device and receives a matching answer.
Why not load the entire import file into memory, check the syntax and dependencies, then run the commands in the right order as a background task?
You’d still have an export file that’s easy to read, and a dropped winbox/webfig session wouldn’t leave you with a partially imported config.
This is likely something the RouterOS export mechanism already does.
However, doing this for every single piece of configuration across all exports is undesirable.
  • I believe many people here have experienced a situation where running an export takes an eternity—often because a process is stuck in the background of RouterOS, resulting in a comment with an error message appearing in the export file instead of the actual configuration for that specific daemon.
    • P.S. 1: I’ve lost count of how many times this has happened to me with BGP and PPP, especially in version 6.
  • Imagine you’re in a rush to export the configuration of a device because it’s behaving erratically. The command might start outputting a good portion of the configuration, but because a process is stuck, the data held in memory is lost—meaning you lose even the parts that were successfully retrieved.
    • You would certainly be worse off than if you had only lost the configuration for the specific, stuck daemon.
Furthermore, if I’m not mistaken, the "export" command isn't actually a global command.
It’s essentially a same-name sub-command that exists within each context menu—each of which corresponds to a Linux daemon responsible for running that specific service.
My understanding is that the "/export" command essentially queues up individual exports from each of these context menus.
  • P.S. 2: I'm my goofie mind - for some reason - using "/export terse" looks easier to visualize how this translates into the .conf files found in the Linux world.
Given this, I suspect they use this workaround—holding the generated output in memory—only for components that are known are really require to do.
Probably because it would be a nightmare (if not impossible) to do it for every entry. And without doing it for all of them, what would be the point? Your diffs would have problems anyway.
They probably use some kind of dependency tree, and walk it from start to end. Some options, in some possible cases, have some dependencies on things that come later, others not.
The development team must have looked into making the export deterministic, and said "Nah, too many variables, too many corner cases. Let's just solve the dependency tree, and let things fall wherever they do."
Then I guess I have been just lucky for many years up until now. The irony is, that I have been waiting for this
release, cause the size of the wifi-qcom-ac package has shrunk substantially which is essential for these devices with limited flash storage. Thanks for the hint anyway.
