711 with hn52 card
Hi to All,
I have started using 711 with hn52 card.
Require to know the following.
How long can i use this for p2p & what maximum throughput i can get.
Currently i am getting a throughput of 10 mbps.
What are the other setting which i can do to get more throughput.
Depends on your connection. With 802.11a u should get around 22-25Mbps with nv2 and wider channel u should be able to get significant more throughput.
