I upgraded the WAN to 700mbps from 300mbps and realized the RB750 is maxed out at ~450mbps.
The bridge is enabled, I assume this is limiting as the in and out bandwidth are both going through the single 1gig link from the bridge to the CPU.
What’s the way to reconfigure to disbale the bridge? I have no specific routes or queues, plain vanilla config two ports (2 and 4) going downstream.
RB750Gr3 is not a speed monster. Look at official test results and you’ll see you’re getting quite good throughput already. (Many forum members find the figure in row “Routing - 25 ip filter rules”, column “512 byte” quite good fit for real-life use cases).
