750G serial
I want to add a serial port to the 750G. What pins could I solder to for rx/tx? I have a 3.3v level converter.
Sell the 750G and buy a 450G… i don’t think there is any other way that would be remotely practical… :slight_smile:
hahaha lol :laughing: :laughing: hurt my stomach
but it is a good advise, only little expensive.
Check four white holes on buttom side.But I don’t think that you can see anything on serial output.
Serial port is disabled in bootloader for 700 series boards. So even if you add serial connector you will not see any output.
