Hi All,
I like to downgrade 750GL from 5.2 to 4.17 version. I have more than 10 pcs. 750GL and I tried at least 5 of them but results are exactly the same.
After restart the routerboard I cannot connect via winbox. I have to reinstall 5.2 with NetInstaller. I am also tried to install 4.17 via NetInstaller but does not work for me.
yes, this is the case. Rule of thumb is - try not to downgrade router lower than version it was shipped, there is usually good reason behind that. (version has correct routerboot to support different parts in revision, version has support for feature at all etc.)
