750gr3 low memory....
memory leaks out… uptime 1 hour
over 24 hours Free memory ~30mb…
installed the dude server + micro SD flsah drive + 4 EoIP tonnel and NAT
dude Server uses lots of memory
it turns out that on this router not work dude server…
Leave it like that, Dude shouldn’t go higher then it is now. I had similar situation, you can see on screen I marked two highest points - those drops are “reboot”
You can see that after reboot it’s stable for a while and then it jumps almost twice…but it stays like that
ok, thanks)
I will observe.
What other packages do you have installed and configured?
I have Dude server running on mine and it hasn’t been an issue in the 10-months or so I’ve had it.
/system resource print
                   uptime: 2d22h27m1s
                  version: 6.40.4 (stable)
               build-time: Oct/02/2017 08:38:30
         factory-software: 6.36.1
              free-memory: 124.2MiB
             total-memory: 256.0MiB
                      cpu: MIPS 1004Kc V2.15
                cpu-count: 4
            cpu-frequency: 880MHz
                 cpu-load: 9%
           free-hdd-space: 4.9MiB
          total-hdd-space: 16.3MiB
  write-sect-since-reboot: 3606
         write-sect-total: 305097
               bad-blocks: 0%
        architecture-name: mmips
               board-name: hEX
                 platform: MikroTik
/system package print
Flags: X - disabled
 #   NAME        VERSION        SCHEDULED
 0   routeros-mmips        6.40.4
 1   system        6.40.4
 2   ipv6        6.40.4
 3   wireless        6.40.4
 4   hotspot        6.40.4
 5   dhcp        6.40.4
 6 X mpls        6.40.4
 7   routing        6.40.4
 8   ppp        6.40.4
 9   security        6.40.4
10   advanced-tools        6.40.4
11   ups        6.40.4
12   dude
