Hello MikroTik forum,
I have a relatively simple request; I want to configure my MikroTik 750Gr3 to work with the Private Internet Access (PIA) VPN service using PPTP. Now lucky for me PIA has a guide which I have followed here https://www.privateinternetaccess.com/helpdesk/guides/other-hardware/mikrotik/mikrotik-pptp-2. However the problem I have is when I create a new route, Step 8, and complete the setup of the PIA PPTP connection I find I am unable to connect to the internet as I receive the following error message in my choice of web browser:
What is strange, is that I am still “connected” to the internet but I cannot actually connect to any website.
Now before I made this thread I followed a few other guides from PIA’s competitors from scratch, https://support.hidemyass.com/hc/en-us/articles/204558497-Mikrotik-Client-Setup and https://nordvpn.com/tutorials/mikrotik/pptp/, however I still get the same problem where it seems that when I set the new route up things fall apart.
For reference this is what my Route List looks like:
Regarding my router configuration, the only thing I have done outside of the basics is implement basic router security practices that were covered in this video:
https://www.youtube.com/watch?v=IAmUTuStZlE
Thanks for the help everyone.
My config below:
nov/29/2018 20:04:51 by RouterOS 6.43.4
software id = W6VX-6J1G
model = RouterBOARD 750G r3
serial number = XXXXX
add admin-mac=XXXX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-Gateway speed=100Mbps
set [ find default-name=ether2 ] name=ether2-WAP speed=100Mbps
set [ find default-name=ether3 ] name=ether3-Homelab speed=100Mbps
set [ find default-name=ether4 ] name=ether4-Homelab speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
/interface pptp-client
add add-default-route=yes connect-to=XXXX.privateinternetaccess.com
dial-on-demand=yes disabled=no name=PPTP-PIA password=XXXXX user=
XXXXX
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=10.0.0.10-10.0.0.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-WAP
add bridge=bridge comment=defconf interface=ether3-Homelab
add bridge=bridge comment=defconf interface=ether4-Homelab
/ip settings
set rp-filter=strict
add comment=defconf interface=ether1-Gateway list=WAN
add address=10.0.0.1/24 comment=defconf interface=ether2-WAP network=10.0.0.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=
ether1-Gateway
add address=10.0.0.0/24 comment=defconf dns-server=10.0.0.1 gateway=10.0.0.1
netmask=24
set allow-remote-requests=yes servers=209.222.18.222,209.222.18.218
/ip dns static
add address=10.0.0.1 name=router.lan
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=drop chain=input comment=“DROP SSH” dst-port=22 in-interface=
ether1-Gateway protocol=tcp
add action=drop chain=input comment=“DROP WINBOX” dst-port=8291 in-interface=
add action=drop chain=input comment=“DROP DNS” dst-port=53 in-interface=
ether1-Gateway protocol=udp
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=“PIA PPTP MARK”
passthrough=yes src-address=10.0.0.2-10.0.0.254
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=redirect chain=dstnat dst-port=53 protocol=tcp to-ports=53
add action=redirect chain=dstnat dst-port=53 protocol=udp to-ports=53
add action=masquerade chain=srcnat out-interface=PPTP-PIA
add disabled=yes distance=1 gateway=PPTP-PIA routing-mark=“PIA PPTP MARK”
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=10.0.0.0/24
set api disabled=yes
set winbox address=10.0.0.0/24
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-autodetect=no time-zone-name=America/Edmonton
/system ntp client
set enabled=yes primary-ntp=74.82.59.150 secondary-ntp=199.180.133.100
server-dns-names=
0.pool.ntp.org,1.pool.ntp.org,2.pool.ntp.org,3.pool.ntp.org
/system resource irq rps
set ether1-Gateway disabled=no
set ether2-WAP disabled=no
set ether3-Homelab disabled=no
set ether4-Homelab disabled=no
set ether5 disabled=no
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
