Hey guys how i can use tp-link 7210 with RB 750Gr3
I need to explain in detail
(…max limit…burst limit…burst threshold …)
thanx
help plz
You might get more of a response if you are more clear on what exactly you need help with.
Also, I do not think it is in the spirit of this forum to just throw your problem over the wall and hope someone catches and resolves for you, at least explain what your problem is, what you have done to try and resolve, etc
My problem is when I connect the 5210g with the router board how to determine the internet speed of this device
finding out your speed? That is called http://speedtest.net right?
But your first question was something totally different - you asked for terms which are in queues/firewall. Best is to open manual for feature, where you are trying to set these up. for example https://wiki.mikrotik.com/wiki/Manual:Queues_-_Burst
