Is there anyway to monitor traffic going trough the switch of 750GS model. I’m running 5.5. Ether1 is master, all other ports are slave. In switch menu a ticked the switch all ports check box, not sure if it is required.
Try running
/interface ethernet print stats interval=1s
Thanks for reply, but .. Yes that prints some stats but i need to see those via snmp so i can get some graphs etc./using the dude atlest/
These counters are not displayed in winbox also.
anyone know how to monitor switch snmp traffic via snmp ?
As far as I know you simply can’t.
ty.
