I have bridged all 5 ports to basically use this unit as a 5-port PoE switch that I can l login to and manage. This works when I plug my laptop in directly to the ports, but not when I stick it on the network a few hops away. I can ping/ssh into adjacent IP units on the same subnet coming off the same 750, but not the 750 itself. Here’s the relevant config:
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=D4:CA:6D:03:71:EF mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:03:71:F0 \
master-port=none mtu=1500 name=ether2-master-local poe-out=auto-on \
poe-priority=10 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:03:71:F1 \
master-port=none mtu=1500 name=ether3-slave-local poe-out=auto-on \
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:03:71:F2 \
master-port=none mtu=1500 name=ether4-slave-local poe-out=auto-on \
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:03:71:F3 \
master-port=none mtu=1500 name=ether5-slave-local poe-out=auto-on \
add bridge=5_bridge disabled=no edge=auto external-fdb=auto horizon=none \
interface=ether3-slave-local path-cost=10 point-to-point=auto priority=\
0x80
interface=ether5-slave-local path-cost=10 point-to-point=auto priority=\
0x80
interface=ether4-slave-local path-cost=10 point-to-point=auto priority=\
0x80
interface=ether2-master-local path-cost=10 point-to-point=auto priority=\
0x80
interface=ether1-gateway path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
no
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.5.74/24 comment="mt750 itself" disabled=no interface=\
5_bridge network=192.168.5.0
