8-Port managed POE/POE+ Switch for use with Mikrotik
Hello.
I’am looking for a cheap managed Switch with 8x POE/POE+ gigabit ports to use it with mikrotik and Voipphones. Anyone has a hint which one i can use ? I does not need to be from mikrotik, as i have not found any product that fits that specifications. The problem is, that many switches are so expensive that the advantage of the POE gets burned by the price, if you just want to use them, because you don’t want to use a separate power supply for the phones.
thanks for help.
Most (if not all) Mikrotik devices use non-standard passive PoE at 12-24V. I don’t know any switch which is able to deliver passive PoE.
I would rather take passive PoE injektor which can be used with any switch
Issue with that is you can’t remote reboot easily. I wish they made a bigger Poe switch
Sent from my XT1575 using Tapatalk
