8-ports switch
Hello!
I develop the network, the question about switches appears :slight_smile: But RB250/260 have only five ports - few! Has MT plans about 8-ports switch developing?
8port NO, but 24port is presented od MUM
http://www.facebook.com/photo.php?fbid=478752605525771&set=a.130192933715075.23710.130187520382283&type=1&relevant_count=1
Yea, it is great device. But “emptiness” between 5-ports and 24-ports is. 8-16 could fill this space. 24 are too much(for us, ex.).
For us would be good 8-10port POE out router. RB750UP have only 5ports :frowning:
We need for example rb2011 with POE out
Do you use it for voip phones or for wireless routers?
Patch-panels are for this.
The theme of thread is SWITCH :slight_smile:
We use poe panels, but better is POE switch or POE router like 750UP but with more ports.
Do you know poe Switch with at least 8ports and POE out voltage 24-30V ?
I was considering the smallest D-Link some time ago because it has .at ports, but decided against it because I wanted something more compact and also not a separate unit.
The little Netgear only has .af ports.
But make sure to verify that the power budget available to distribute is enough for you.
So for now I got no PoE out until there is a fitting router offering it.
Know, but adversite is excessive. Ok, lets it be switch with 8 ports and PoE :slight_smile: However, now it is not. Would like to know, will be or not
