802.11a Link with wds setup...
Hi all…
Recently i have try to make my new setup more faster with the easy way, here is the sharing you can try when you wanna setup for the new link with wds.
Appreciate for any feedback from you.
For Version V4.x and above…
Login via Mac Address, remove the configuration, Then Copy and Paste into the Routerboard New Terminal)
5Ghz AP [Access Point] Configuration:
system identity set name=Mikrotik_AP
interface bridge add name=wds-bridge-eth1 protocol-mode=rstp
interface bridge settings set use-ip-firewall=yes
interface set wlan1 disabled=no
interface wireless set wlan1 mode=ap-bridge band=5ghz ssid=iGate radio-name=Acess_Point frequency-mode=superchannel default-forwarding=no hide-ssid=yes
interface wireless set wlan1 scan-list=5150,5160,5170,5180,5190,5200,5210,5220,5230,5240,5250,5260,5270,5280,5290,5300,5310,5320,5330,5340,5350,5360,5370,5380,5390,5400,5410,5420,5430,5440,5450,5460,5470,5480,5490,5500,5510,5520,5530,5540,5550,5560,5570,5580,5590,5600,5610,5620,5630,5640,5650,5660,5670,5680,5690,5700,5710,5720,5730,5740,5750,5760,5770,5780,5790,5800,5810,5820,5830,5840,5850
interface wireless set wlan1 hw-retries=10
interface wireless set wlan1 wds-mode=dynamic wds-default-bridge=wds-bridge-eth1
interface wireless nstreme set enable-nstreme=yes enable-polling=yes disable-csma=yes wlan1
interface bridge port add interface=ether1 bridge=wds-bridge-eth1
sn community remove 0
sn community add name=public address=0.0.0.0/0 read-access=yes
sn set trap-community=public trap-version=2
sn set enable=yes
ip address add address=192.168.1.1/24 interface=wds-bridge-eth1
ip route add gateway=192.168.1.254 check-gateway=ping
system reboot
yes
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~End~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
5Ghz CPE [Customer Premise Equipment] Configuration:
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~Start~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
system identity set name=Mikrotik_CPE
interface wireless set wlan1 mode=station-wds band=5ghz ssid=iGate radio-name=Customer_Premise_Equipment frequency-mode=superchannel
interface wireless nstreme set enable-nstreme=yes wlan1
interface bridge port add interface=wlan1  bridge=wds-bridge-eth1
sn set enable=yes
ip address add address=192.168.1.2/24 interface=wds-bridge-eth1
system reboot
yes
Happy Trying...
:sunglasses:  :sunglasses:  :sunglasses:
