802.11ac and 802.11ax on CAPsMAN
Is it possible to configure the hAPax2 with local wifi interfaces running in AX standard and activate CAPsMAN to manage two other cAPacs?
If possible, could someone tell me the necessary steps?
I have one hAPax2 (CAPsMAN) and two cAPac.
Thanks in advance!!!
The only way to do this, is to uninstall the qqireless package and install the wifi-qcom-ac package on the cAP ac.
More info can be found here:
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-Advancedexamples
And here:
https://help.mikrotik.com/docs/spaces/ROS/pages/40992872/Packages
Basically (on the cAP ac):
  • Uninstall wireless package
  • Reboot
  • Install wifi-qcom-ac
Ater installation, both devices are now available to be managed by the latest CAPsMAN version.
There is a YouTube video about that:
https://www.youtube.com/watch?v=bHotZT41w3E&t=89s
But also you can use the documentation for that:
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-CAPsMAN-CAPsimpleconfigurationexample:
Thank you very much Erlinden!
Your guidance was extremely important.
Both cAPacs are now working perfectly.
Regards.
