802.11ac P2P Link -> 500+ Mbps
Today i created a wireless point to point 802.11ac link with MikroTik devices.
The equipment i used:
MikroTik NetMetal 5 + 80cm offset satellite dishes + Dual Feeder + 2x 2m LMR200 RPSMA-to-N-Male cables.
The results are great.
Distance = 160m
Tx Power = 0
Signal = -40dB
CCQ = 100%
I saw 500+ Mbps one way during UDP Btest at 80MHz using NV2.
Some fotos:
802.11ac vs 802.11n:
20MHz
N=100+Mbps
AC=130+Mbps
40MHz
N=220+Mbps
AC=280+Mbps
What about TCP? Please run TCP tests and post it here.
BTest from netmetal to netmetal 80MHz - nv2 - one way - tcp 1 connection = 180-190Mbps
I will upgrade the main router + switch to gigabit and i will post the results with iperf pc to pc.
