802.11af
Hello All,
Does MikroTik have any devices that support 802.11af wireless networking standard? I’ve tried doing a search, but all I end up with is a whole bunch of hits on people mistakenly using 802.11af (the WiFi standard) as the key phrase when they really mean 802.3af (the PoE standard).
The reason I’m asking is because I think it would be useful for some industrial applications where you might want wifi delivery on a forklift that’s bombing around out in the yard behind a factory or a warehouse. A good example of where this would be useful is a lumber yard because the lower frequencies could penetrate the lumber a lot better than 2.4GHz could and it shouldn’t be as crowded of a spectrum as 900MHz (802.11ah).
Thank you.
Daniel Lynes
No, we don’t.
Thank you Normis. As always you’re helpful.
Normis you can support it in markets where there are no standards for Wi-Fi regardless of standards, I can test an 802.11af standard in MikroTik LtAP LTE kit form factor I will commit to buy 1,000,000 units exclusively.
