Personally I only connect clients that have a signal of at least -70 db at the day of installation with a SNR of at least 20 db. The Equipement gets not really better when it’s older, so you need some margin that you have a “real - life - performance” of at least -75 db even at bad weather conditions, with some more noise in the area etc…
If I can’t get a signal like that I check if there are more customers in the area around that said customer, if so, I build a new AP near to them to get good signal. If it’s the only customer in that range, I’d rather tell him to wait, look for some neighbors interested too, or choose another (W)ISP than connect him to my AP’s with a weak signal.
with SNR of 20db + and signal of -70db + all your clients will stay at least at 36 to 54 MBit rate (most of the time it’s 54MBit).
The weaker the signal or SNR gets, the lower the rate you get, with one or two bad linked clients your AP will switch down to 6 MBit or less very often, so you don’t have much traffic going over that AP (mind you, 6 MBit is the “name” of that rate, 3 to 4 MBit is more like what you get at all. Then having 20 clients who have to split that 4 MBit with overhead for csma etc, you will have about 20 unsatisfied customers, because of one or two weak links.)
With good links for ALL clients, you could have 20 very satisfied customers on the very same Hardware. There’s no absolut max. possible users on one AP, but the viewer, the better for everyone. With standard 802.11b/g I guess 20 clients would be the upper limit for good service quality, because not all of them will be transferring lots of data at the same time.
With Nstreme and polling, csma disabled, you could go up to 30 to 40 clients on one AP, because the overhead for csma is gone.
All these figures are “rule of thumb”, you have to test the performance of your setup from time to time and listen to your customers complaints (if there are any).
I would also make sure none of your clients has a signal higher than -50 db, because that could also cause you some trouble, too. Reduce their transmit power (and / or antenna gain) until the signal fit’s your need.
If you are going to switch to 5 GHz I would suggest you go all the way with mikrotik (AP and client side). The client CPE will cost you with 17 to 19 dbi antenna, poe, RB411, R52 about 100-130 Euro. It’s a bit more expensive, but if you calculate with 24 months of using it, well, 5 Euro a month is not that expensive at all. And your service quality will improve a lot. You can manage your network up to every client cpe with one interface, you could use RB433 at some clients where you need another AP in the area, just put in 2 R52, one for Backhaul, one for AP, one ether NAT to wlan-bridge, and the client will be served well, and you have yourself a nice new AP for little money.
Sincerly
Schnulch
