802.11n 2 radios each point.
I test this situation:
2 boards x86 1.6Ghz with 2 sr71 (5Ghz) each board.
When try 1 link with wlan1<–>wlan1 I can reach 130 Mbps TCP!! But when I start bandwidth test with wlan2<—>wlan2 same time, then two links low to 20Mbps..
Link wlan1 : 5180 Mhz
Link wlan2 : 5800 Mhz
This is a bug? problem with radio MIMO controllers?
What mPCI to PCI adapters you use?
2 separated miniPCI.
No one has detected the problem? I try with diferents radios, r52n, srt71, compex, etc…
It’s clearly a huge mikrotik routeros problem Fumi22.
Why do you thing noone of official support team reply to this topic: http://forum.mikrotik.com/t/2x-parallel-vpls-tunnel-in-the-same-time/36306/1
They simply passed to reply cause TCP bandwidth collapsed when we use two MIMOS radio [with or without nstreme-dual]
I try all and always reproduce the problem.. I don’t know if it’s my problem. :frowning:
