I have a new RB433AH and MT R52nM card.
My client registers just fine and gets decent receive btest results of 64 Mbps for as long as I want. If I stop that test and do a send btest, I peak at 10Mbps for a few seconds…then it goes down to 0, then back up to 10…then back to 0. During this up/down time, I have successful pings…then they stop when test is at 0…then they are successful again.
My config is below.
Also…of note…if I enable the 54Mbps rate, my btest result actually goes down. Same if I enable MCS 5,6, or 7.
Here is my registration table. The first is when doing a “receive” test…the second when doing a “send” test.
0 interface=wlan1 mac-address=00:23:14:D4:EB:84 ap=no wds=no rx-rate=“48.0Mbps” tx-rate=“90.0Mbps” packets=637946,134657 bytes=962757824,201128350
frames=637946,134662 frame-bytes=964033724,200320920 hw-frames=662017,134745 hw-frame-bytes=984907094,205720028 tx-frames-timed-out=0 uptime=11m47s
last-activity=0ms signal-strength=-73dBm@48Mbps signal-to-noise=40dB
strength-at-rates=-71dBm@6Mbps 7s870ms,-73dBm@9Mbps 1s200ms,-72dBm@12Mbps 1m26s870ms,-71dBm@18Mbps 10m45s990ms,-70dBm@24Mbps 1m34s260ms,-71dBm@36Mbps 3s110ms,-
73dBm@48Mbps 100ms,-70dBm@54Mbps 11m46s790ms
tx-ccq=100% p-throughput=74325 distance=1 last-ip=192.168.111.254 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm
group-encryption=aes-ccm wmm-enabled=yes
[admin@MikroTik] /interface wireless registration-table> print stats
0 interface=wlan1 mac-address=00:23:14:D4:EB:84 ap=no wds=no rx-rate=“48.0Mbps” tx-rate=“6.0Mbps” packets=665351,151202 bytes=1003963836,225927860
frames=665351,151207 frame-bytes=1005294546,225021160 hw-frames=691668,151290 hw-frame-bytes=1027278416,231082068 tx-frames-timed-out=0 uptime=12m40s
last-activity=840ms signal-strength=-70dBm@48Mbps signal-to-noise=43dB
strength-at-rates=-71dBm@6Mbps 1s320ms,-69dBm@9Mbps 1s300ms,-72dBm@12Mbps 2m19s920ms,-71dBm@18Mbps 11m39s40ms,-70dBm@24Mbps 2m27s310ms,-71dBm@36Mbps 1s180ms,-
70dBm@48Mbps 840ms,-70dBm@54Mbps 12m39s840ms
tx-ccq=48% p-throughput=5535 distance=1 last-ip=192.168.111.254 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm
wmm-enabled=yes
[admin@MikroTik] /interface wireless> print advanced
0 R name=“wlan1” mtu=1500 mac-address=00:0C:42:64:BE:60 arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name=“000C4264BE60” mode=ap-bridge
ssid=“mt-n” area=“” frequency-mode=regulatory-domain country=united states antenna-gain=0 frequency=5180 band=5ghz-onlyn channel-width=20mhz scan-list=default
wireless-protocol=802.11 rate-set=configured supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic tx-power-mode=default noise-floor-threshold=default
noise-floor-offset=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=secure
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00
ht-ampdu-priorities=0 ht-guard-interval=any ht-extension-channel=above-control
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-basic-mcs=“” ht-txchains=0 ht-rxchains=0
ht-amsdu-limit=8192 ht-amsdu-threshold=8192 tdma-debug=0 tdma-override-rate=disabled tdma-override-size=0 tdma-period-size=2 nv2-queue-count=2 nv2-qos=default
nv2-cell-radius=30 hw-retries=4 frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 frequency-offset=0
My client is a Lenovo T410 with a factory Intel AGN card. Doesn’t get much more mainstream than that.
Thanks for any input.
Scott
